It is currently Sun Jul 27, 2025 6:15 pm
PostPosted: Sun Aug 28, 2005 6:05 am
As I was cutting the rosette channel in a very nice Italian spruce top, the set screw on my rosette cutting jig decided to work its way loose, causing a bit of a gouge in the top.
I didn't want to scrap the top, so I decided to do a little inlay to cover the offending area..I am not a big fan of soundboard inlays, but I couldn't see using this top for firewood!
Anyway, here are the preliminary results, the top still needs to go throught the thickness sander, and the inlay needs some engraving, etc., (possibly even some green ab antennae), but so far, it's looking OK.
The inlay is gold MOP, green ab, a bit of black MOP, and the whole inlay is framed in a thin black veneer. The rosette ring is paua ablam.
Inlaying into spruce is a little daunting, to say the least! Now that I have done this on the soundhole, I may have to go all the way, and make the rest of the guitar fit the butterfly (or insect) theme...maybe just a couple of small butterflies in the end graft...hmmmm....
PostPosted: Sun Aug 28, 2005 6:14 am
Very creative solution. Better craftsman aren't perfect, they just know how to hide a mistake or, better yet, turn it into a feature.
Mark Joy
mjoy Guitars
PostPosted: Sun Aug 28, 2005 6:48 am
Nice recovery. I doubt I could ever do that...
PostPosted: Sun Aug 28, 2005 7:00 am
Good job! I have not been able to make a butterfly that I like.
Mark Swanson
Swanson Guitars
Russ that looks terrific. If you didn't say anything it would look like it was planned that way. Nice job.
PostPosted: Sun Aug 28, 2005 7:11 am
Yeow! That's some tight, tight inlaying there, and a very elegant design to boot. Nice recovery!
PostPosted: Sun Aug 28, 2005 7:24 am
absolutely georgeous. I'm sure the stuff I do "as planned" won't turn out
like that!
PostPosted: Sun Aug 28, 2005 7:37 am
Mark,
I found a pattern book of Japanese designs that had this butterfly in it (along with lots of others)...I can't draw to save my life!
PostPosted: Sun Aug 28, 2005 7:39 am
That looks great. Can I send you all my mistakes?
PostPosted: Sun Aug 28, 2005 7:53 am
Very nice, Russ. I agree that a couple more small butterlies would be good. Maybe have one perched on your logo. Just don't go overboard. You don't want it to look like something out of the Grizzly catalog
PostPosted: Sun Aug 28, 2005 8:12 am
Beautiful!    Put a caterpillar on the 12th fret.
PostPosted: Sun Aug 28, 2005 8:23 am
I was thinking a cocoon...then a caterpillar....maybe that's too much!
PostPosted: Sun Aug 28, 2005 8:27 am
That would be too cool, Russ. Fret markers of increasing size cocoons, then a caterpillar, to that great butterfly.
PostPosted: Sun Aug 28, 2005 8:31 am
Hamana Hamana Hamana Hamana Hamana Hamana Hamana Hamana!
That looks AWESOME!!!
What mistake?? it was an opportunity...
Great Work...
-Paul-
-Paul-
Patriot Guitars
PostPosted: Sun Aug 28, 2005 8:47 am
Russ, fantastic recovery! I have to agree with Paul, it was an opportunity!
PostPosted: Sun Aug 28, 2005 8:48 am
Watch your back Craig...Russ is sneakin' up behind you!
Nice work Russ!
PostPosted: Sun Aug 28, 2005 8:49 am
Do you guys think i should make the soundhole bigger, or leave it this size??
PostPosted: Sun Aug 28, 2005 8:55 am
[QUOTE=russ] Do you guys think i should make the soundhole bigger, or leave it this size?? [/QUOTE]
I'm thinking just a hair bigger. Tiny amount.
PostPosted: Sun Aug 28, 2005 8:58 am
Uh...yeah good point! I recommend AGAINST using a circle cutter for this one! You're going to want to shape the soundhole differently, so perhaps a router setup to cut it round part way would be a good thought.
PostPosted: Sun Aug 28, 2005 10:39 am
Nice Work Russ
PostPosted: Sun Aug 28, 2005 12:28 pm
Nice recovery Russ. If you go with the caterpillars and coccoon scenario, have the caterpillars get larger. The cocoon doesn't get any larger once formed and sometimes are just a bare pupae (which might be more interesting). How about an egg at 5, small caterpillar at 7, full caterpillar at 9, and cocoon at 12th. Hey, I can't help it...I'm bug person Actually, I don't think it will need any more inlays to look good and might actually distract from the nice butterfly you created.Don A38592.8959606482
PostPosted: Sun Aug 28, 2005 1:29 pm
I've dome it both on purpose and by accident and have always enjoyed the outcome. Nice creative work!!
Regards,
Kevin Gallagher/Omega Guitars
PostPosted: Sun Aug 28, 2005 2:23 pm
Yep, if ya can't hide it, make it pretty! Good job!
PostPosted: Sun Aug 28, 2005 10:33 pm
State: ON
I'm going to add this idea to my bag of tricks. Great work!
Josh
Josh House
Canadian Luthier Supply
http://www.houseguitars.com
PostPosted: Mon Aug 29, 2005 3:45 am
Great job, Russ. I'm with Don, any more might distract from the elegance of that one butterfly. Less will be more. As for the shape of the soundhole, cut it normal up to the butterfly, then leave a margin of spruce around the wings--protruding into the soundhole--and further outlining the shape, as well as lending support.
Harry Fleishman does stuff like that.
Looking forward to your next mistake!
